Hi folks,
New to the forum. Using discogspone 4.4. Trying to get the comment field to automatically populate with catalog# from discogs, but havent had any luck. Any ideas?
Thanks in advance!
Hi folks,
Thanks in advance!
You have to enter comment into the config file and generate the scripts again.
Pls read the instructions on the dedicated Pone's thread.
I tried doing just that but I must be doing it wrong.
What exactly has to go in there? "Catalog #" or ":>catalog #" or?
Normally you see the following in "LABEL & SERIES" tag.
Label: >PUBLISHER
Label #: >CATALOG #
if more than one label:
- only the first >no
- multivalue tag field >yes
- list of names >no
- seperating characters used in list >,
Series: >PUBLISHER
Series #: >CATALOG #
if more than one series
- list of names >no
Replace Catalog # with comment as below.
Label #: >Comment
Series #: >Comment
Save
I was doing it all backwards. Thank you very much!
Label: >PUBLISHER
Label #: >CATALOG #
- list of names >no
Series: >PUBLISHER
- list of names >no
Label #: >Comment
Series #: >Comment
Save
