Discogs cover art
Greetings,
I have been using Mp3tag with discogs to import and download covert art for the last 5 years or so and I've never experienced any problem.
But since 2 or 3 weeks, I have been unable to do so and I do not understand why.
The other tag info importation from discogs works just fine. But the cover art just does not show up anymore...
Any idea what's happening?
Cheers.
Hello everyone. I am experiencing the same issue. Looks like it's not possible to fetch the artwork from Discogs.. Any workaround ?
(I'd also like to thanks the developers for creating this wonderful piece of software)
Anyone?
It used to work quite perfectly...
/t/15459/1
Still can't make it to work... But thanks!
Guess I'll have to wait for an update.
I have the same problem as you.
I hope soon corrected the error
Check the page
/c/web-sources-scripts
to get updates for web sources scripts. You would have to download and install them yourself, though.
I've added authentication via OAuth with the latest Development Build.
This will bring back support for cover-art from Discogs (but still with the 1000 hits/day limit for all Mp3tag users).
