Would it be possible to make a script that would work with Discog's digital release listings:
http://www.discogs.com/digital
I should be possible.
If somebody takes the time to do it...
I think it's completely independent from the standard discogs database.
Hello Pone , just a question , Can you make a script for Traxsource or , is this impossible ?
With the problems with beatport & junodownload it would help to have this as a 3rd option if possible.
sorry, no scripts from me for discogs digital or traxsource in near time.
if anybody volunteers to do the main work, I will be happy to help at some problems.
