Hi. I'm having the same discogs problem. And I tried the new version of Mp3Tag. Plus those scripts. I can see the album art. But otherwise error for the album. And no results for all the other categories. It use to work good. Maybe it's the website. Oh well, still have MusicBrainz. And the Walmart album script does not work at all.
All discogs scripts work at the moment!
Use search!!!
The last topic in this forum (Genereal Discussion) is exactly the same question as yours!!!
discogs doesn't work
pone some results from the discogs search seem to lack the tags every now and then causing an error as "format" "publisher" and "catalogue" are parsed.
Can you please give links to the releases which are causing problems.
discogs is down for me atm.
