Hi - Having a problem with Discogs ID not accepting Paste command.
Thanks, Wayne
A little more information would be helpful - like what you have attempted to do in which context.
Otherwise the reply would be: can't reproduce it, works over here.
my problem is similar to the one mentioned above: When pasting the ID number [r2697477] into mp3tag mask than I get following message:
"Es wurden keine Einträge zu Ihrer Suchanfrage gefunden" (tranl. "no entries found to your request")
i.E. it worked for this ID number [r10854286]
It works here with both mentioned realease IDs,
In my case only 15-20% of my request are working.
It should work if you leave out the 'r'
I just tried without rectangular brackets and r. It don't work.
When it works than with the whole code [r#] as well.
Are you using this manually or via some external automatic process. If manual, are you maybe on a VPN that shares the IP with possibly many others?
I'm mainly asking because Discogs enforces rate-limiting if more that 60 authorized requests per minute from the same IP arrive at their servers.
I copy and paste the ID manually and I'm not using VPN.
What's the exact name of the script you use?
I think I'm using the default script. I didn't installed something new. Where I can find the script info?
In the "Tag sources" menu there should be several options with Discogs. If you want to use the ID you should choose "Discogs Release ID"
ok thank you, it seems I used to often the wrong script, sorry for my stupidity
Is there any tool to edit a script to fit the own requierements?
A text editor can be used to edit scripts.
Sorry to be so late with reply but I found I had to be logged in to Discogs (Username/Password) then problem went away.
Stay safe, Wayne
