When looking for cover art and music details I choose Discogs as recommended but get an access denied. I have an account with them and are logged in as far as I know. I get this error most of the time. On a rare occasion all goes smoothly as expected. So what is going on here? I was using the Amazon connection but I know is not available now.
Can you check your system time and ensure that it's set correctly?
Kind regards
– Florian
I am having the same issue, using MP3Tag 2.83 on Win 10. My system date and time is correct.
Specifically, I am getting a "401 Unauthorized" error. I am logged into Discogs.com, with a valid account.
Thoughts?
Another issue, which I've just remembered, has been fixed with v2.83a Development Build FIX: dot and underscore characters where percent-encoded when querying Discogs which resulted in HTTP 401 error.
You can download the current beta version from here.
Kind regards
– Florian
I downloaded this beta today. I was successfully able to access Discogs; it found the album I was trying to locate. Also, I was able to download just cover art from Discogs, as well.
So this beta seems to have resolved my issues with Discogs. Thanks!
That's good news! Thanks for confirming the fix ![]()
Kind regards
– Florian
