Added "extraartists" capture in the Composer and Performer fields to Discogs Release ID.src
Feature
COMPOSER - Extract and normalize roles (even concatenated), separate output
set "TEMP_LyricsBy"
set "TEMP_MusicBy"
set "TEMP_WrittenBy"
set "TEMP_ComposedBy"
set "TEMP_WordsBy"
PERFORMER - The capture excludes these roles:
Written/.By
Lyrics/.By
Music/.By
Words/.By
Songwriter/.By
- it does not combine equal roles, if you want this install Script Pone
- Remove anv
Discogs Release ID Plus.src (13.4 KB)
See you
Great work, thanks!
Would you share how you came choose the tag PERFORMER?
Are mixers and producers considered performers? Just out of curiosity.
Hi, I understand your observation, I should have used mixartist or Album Artist, I usually work with Pone. I only use this in certain distributions combined with an action that copies the content of "Performer" in "Album_Credits" (also the other way around if necessary) and then from "Extended Tag" I manually eliminate the excess roles. From my experience I have never found a script that can replace a man in objective choices. As you may have guessed I like to customize the where to insert the tags
, I do not use other players outside of Foobar2000 and here I can insert my preferences. In the photo my typical Tag information
Best regards
