When clicking on Tag Sources -> Discogs (any of the options), the sign in to discogs.com fails with an invalid redirect error.
This seems like an issue that happens on your computer only. Which browser are you using and can you post a screenshot of the invalid redirect error you're observing?
I've also removed your other topic on the same issue. Usually it's enough (and encouraged) to not cross-post to different categories.
This looks like something outside of Mp3tag's (and my) control. I've just tested this from various systems and it works without redirect issues.
Can you login to your account as described here?
