Hi all may a say what a great program and some top scripts for discogs
Im using discogs#Search by Artist + Title
this works a treat for finding the item on discogs but i want to modify the output so it Only does
1 = adds the discogs id to comment field
2 = adds track/lp artwork to file
Also is there a way to open up a folder with say 20 various files and get it to batch process them 1by1 to add the above to actions only
