Display Lyricist
For tracks I display the following:
Track Filename Title Artist Composer Length
Is there any way to display the Lyricist (ID3Tag - Text)?
If not is it possible to add it to the available display Tag List in a future update?
JerryBo
see the documentation about how to customize the file list:
and/or the tag-panel:
and the supported fields in MP3tag:
If you already have files with the lyricist, then check the extended tags dialogue to see the field name.
Hi ohrednkino
Thaks a lot!! I must have been blind.
Jerry B
