For starters, this is the single best dedicated tagging program out there, hands down. Now I realized that it will grab album artwork and add it to the tag. My question is though how can I tell (aside from looking in the folder in windows explorer) if there's album art associated with a particular file. I checked around customizing the fields, but nothing there. Is there a specific tag name in the file for the artwork? ie. that type of idea? Basically is there a way in mp3tag that I can tell what album artwork I have? I would be even happy knowing what files DONT have artwork.
Hmm...Maybe I am missing something here. I have quite a few of my files that contain artwork, and a few that the image is written to the tag. I am not sure which this entry is picking up. For example, I just did a lookup for "Chicago-Twenty 1" on Amazon. It tagged it, and pulled the album artwork. I verified its in its folder. However, mp3tag doesnt show anything in the cover field. But there are quite a few files that do show a value for cover, which is a "1". Any ideas? Or how bout a bitchslap to point out what i am missing. I am kinda lost.
I've the same problem here... Making a column with Cover as the name and the field and value set to %_covers% doesn't display artwork in the files... Even though it HAS been written to the tag, since iTunes correctly displays it, and only accepts images in a tag. iTunes simply can't handle external images... And when I press ALT+T everything works fine.
An additional confirmation of the fact that the cover has indeed been written to the tag may be found here: I have tried to rename and delete the original files to see if they were still displayed: yes they were; even when forcibly updating the tag display information. So obviously I must be doing something wrong down here, since I've read about people getting it to work with the column... Could you hand me some additional tips?
Mp3tag 2.35:
Placeholder is $covers() - you must use this one
Mp3tag 2.35b and higher:
Placeholder is %_covers%
Yes, value is not needed!
But I wouldn't use $if(%_covers%,x,) since it only displays "x" if you have a cover, whereas %_covers% returns the number of images, so you see if you have 1 or more images in the tag.
Nah... Still doesn't do the trick... The Cover column stays as empty as empty can be... Doesn't even report IF there's a cover, let alone show it... And all my other MP3-software (Windows Media Player, iTunes, WinAMP) shows it... So all I can say is that there's definately a cover in the tag... As is confirmed whenever I press ALT+T in Mp3Tag v2.35. I've even added the covers using MP3Tag, and of course I did click the Save Cover To Tag button, or else the other apps wouldn't have displayed the cover... I'm at a loss for what to say...
All right... Now I indeed get a 1 beside every track, since there's one cover per track for these tracks... Is there (or will there be, in the near future) a way to display the actual cover, exept for pressing ALT+T? i.e.: selecting a different View, as is possible in Windows Explorer?
Btw: the placeholder used in my case is indeed %covers()
