I cannot see the description of a podcast on my iPhone, unless it has been stored as the "Lyrics" (using iTunes).
The description is available in the ITUNESPODCASTDESC tag -- but this does not display on the iPhone.
Any suggestions?
Thx,
Bruce
Any suggestions?
Thx,
Bruce
If you really need it to be displayed you can just copy the information from ITUNESPODCASTDESC to UNSYNCEDLYRICS using a Format value action.
Kind regards,
Florian
Thanks. Works great.
B/
