Anyone have any docs for the filelist right-click menu? Esp. shortcut keys. I'd like to e.g. Play with one keypress. Thanks.
Play is F4
The help file also has a list but it misses some.
Play is F4
Thanks.
Indeed. ALT-T's another one needing adding.
If any one has a fill list, I'd be grateful. Thanks.
PS Suggestion to Florian if he is reading: Re "Find topic in Help", it would be nice if this finding was done by mp3tag rather than the user! ![]()
Or does this label just mean "Contents"?
Thanks, I'll add it.
Yes, I'll change it to "Help contents". Please let me know, if there are any other language quirks.
Best regards,
~ Florian
F2 .. Rename
Better is "Contents", I suggest.
