Does changing a riff formated wav file to id3 wav formatted file affect sound quality?
Several wav files I have is in riff format. If I convert it to id3 format using this program, will it effect the sound quality? Even when I edit the same file multiple times by constantly changing the tags or album art?
No, it only affects the metadata and leaves the audio part untouched.
