sorry if this newbie question has been covered off elsewhere; I have scanned the forums and help files - everything I see seems to be way more detailed than what I am stuck on....
simply put, currently @ 90% of my music collect has cover art associated with it... ie when I import it into iTunes almost every album has a cover art image that comes up automatically. those that don't I have used the itunes feature to fetch cover art and this usually works, a few times I have had to search (Google) album art and cut & paste a image file in. Having just reloaded my music collection into a new install of iTunes I see that all the changes I had made to files including adding missing art, changing genres etc has all gone and needs to be redone - hence I am trying out Mp3tag as way of finding a way of permenantly "correcting" these files...
having just loaded a large number of albums into the mp3tag software, I am confused as to why I do not see any album art assocaited with any of my files... looking at the default view with the Tag Panel and there is a basically empty white box at the bottom with a faint swirl graphic in it....
how can I see which allbum / files have art and which ones do not, and then "attach" art to those that do not?
I tried on one file the Tag Sources>Cover Art tool to locate cover art and select etc but still nothing shows in the Tag Panel....?
