Hey,
I'm sure this has been asked before but I can't find it.. and the one solution I did find didn't work.
Is it possible, using regular expressions, to put 0's before all file names with single digit (1-9) track names? All my files are named: 1 - song name, but it should be 01 - song name
I figured out the auto numbering system too late and I have a LOT of mp3s that need to be renamed. If not a way to rename file names, surely there is a way to add 0's to only single digit track numbers so I can convert tag -> filename?
Use autonumbering wizard to renumber them, there is an option for the leading 0. Then use the Tag>Filename to rename. Be careful that you don't change the significant digit of the track, I would recommend doing one album at a time. Perhaps copy a few folders over to a temp folder and practice on that until you are comfortable doing larger batches.
