I would like to be able to manually move the track order, then apply the auto numbering. Is there a way to do this?
Thanks
C
Right right on the top of any column >customize columns or at the menu>edit>customize columns and do as attached and put '%discnumber%%track%'. This ensures disks are sorted first then tracks. You could also put %album% before %discnumber% to ensure better sorting. Since I only work with only a handful of files at a time this is not needed so much.
Just wondering are you aware of the Web Source Scripts on here. /c/web-sources-scripts
EDIT:
Sorry misunderstood the question!!
ALT key and drag files
Hold down ALT key then drag the files. Ur use ALT+Up/Down
ALT! sweet, thanks!
C
Maybe it's in the docs somewhere but this was also (most welcome) news to me.
Suggestion: perhaps an indicator of this functionality could be pointed to in the UI for the Auto-numbering wizard?
