New bug in 3.30. I can no longer drag art from another program (Album Art Downloader 1.0.5.0 - Album Art Downloader download | SourceForge.net) into Mp3tag. Dragging files from File Explorer still works. This used to work in previous versions (confirmed working in 3.29).
You have to press the CTRL-key while dragging. See the release notes for version 3.30.
I'd missed the note about using CTRL. Thank you, that works!
I've also noticed that some programs don't support move via drag and drop. I changed the behaviour with Mp3tag v3.30b to use copy instead, if move is not supported — even if Ctrl is not pressed.
