Drag And Drop artwork issues
Hello Florian,
This feature has worked flawlessly for me for years when tagging, but within the last month or two I notice a handful of tracks with each batch that I tag fail to update the artwork in finder and in the Music app.
I’ve flipped through similar issues here and have tried a few things, unsuccessfully. Just now I found I was not at the latest version, so I upgraded and tried again. Still have blank artwork outside of your app.
I’m attaching a screenshot of behavior after the upgrade to version 1.9.11 (127). No change.
I’m running Sonoma OS 14.6.1 and using Firefox 144.0.2 (aarch64) for the artwork search
Thanks!
Can you check what it says
here?
Aha, you are right! All of the 5 files say image/webp!
