For some reason, this happens to me a lot (evidently I can't aim)...
When I think I'm scrolling I'm actually dragging at the extreme right hand side of the file list. What happens after I do that is it loads that subdirectory only. Is there any way to turn off this behavior, even if it's in the registry only?
He thinks that he is moving the vertical scroll-bar but he is actually drag-and-dropping a file which on release causes MP3Tag to load the directory where the drag-and-dropped file resides. I prepared a small movie to demonstrate this since it's pretty hard to explain the behavior.
Attachment 254 not found.
It is not a bug obviously, but he is asking if it is possible to disable the current behavior.
I could try to detect, whether Mp3tag is the drag'n'drop source and disable drag'n'drop in these cases. This way you won't be able to load subdirectories using drag'n'drop.
I don't know if someone is using this feature and will miss it
Thank you as well Sebastian, that's exactly what I meant. Florian, if you're able to detect if it were coming from mp3tag, that would be a great help. Thanks
I know i have done this a few times. It does get annoying when you are working with a large group of files form various subdirectories and inadvertently do this and load only the directory of the dragged file.
I've been using this "feature" a lot after discovering it by accident too, although I guess I wouldn't really mind if it was taken out.
At first it was a bit annoying but I found it's quite a quick way to traverse into a subdirectory, in fact, I think I use it so much I don't think I even know another way to go into a sub directory!
