Hi guys,
As I don't think this is an Mp3tag problem, I'm posting in general!
Since moving to Firefox 3, I can't drag cover art to the extended tag window from Firefox like I used to (IE still works ok) (using 2.41)
Anyone got any clues..?
Hi guys,
I've changed Mp3tag's drag'n'drop handling to work with FF3 again. You can try it with the current Development Build Mp3tag v2.41b.
Kind regards,
Florian
Thanks! Works great now.
what do you mean ?
you can drag artwork from a FF window onto a list of songs in Mp3Tag ?
Yes, drag & drop it on the picture panel in the left handed tab panel and save the tags.
Look at this picture at number #5: http://www.abload.de/image.php?img=mp3ag6sq4.jpg
Try a right click on the panel too, there are some other thongs you can do.
