Hello @Doug_Mackie,
I think Florian is doing an excellent job with Mp3tag. I really like it when he adds new commands; it's great, I haven't seen that in other tagging programs...
As for the icons, as you said, it's hard to break old habits...
@AreDigg says:
But my opinion is that the old icons feel very windows 3.1/95. The newer icons are certainly fresher, and adding colors like in arb's suggestion seem like a middle-ground, or more varied accents on the icons.
I think AreDigg is right about the old icons feeling very Windows 3.1/95.
That might explain our attachment to those icons...
In 2000, the great program Mp3tag was born, and Windows 98 was replaced in 2000 by Windows 2000.
I think some of us like those icons in Mp3tag because they were there, I believe, from the very beginning of the program. For me, the icons are part of the history of Mp3tag...
For the past few years, I've always worked with these icons at 125% size, which I find fine. I know where my frequently used icons are.
I installed the new version to test it on two computers, and I often have to search for or click on the right icon, especially towards the middle of the icon list...
Speaking for myself, I don't really like working with keyboard shortcuts, but Mp3tag allows us to do so much more efficiently. to work with the mouse...
@Doug_Mackie, I found your writing very interesting:
"Tell us, Oh wise man"
, you showed us a toolbar, you can even create custom icons with the application you call wonderful, which can do all that?" It's Lotus Word Pro...
That piqued my curiosity. Is it possible for you to program your icons for your personal needs with Mp3tag?
I have a program project, which should be released before this summer for us radio programmers, that will be 100% compatible with our tags using Mp3tag. I also had a programmer design a ToolsBar specifically for Mp3tag, which allows us to click on the first 10 Mp3tag tools with the mouse. It's very quick to use.
(It's faster than using the invisible toolbar on the screen. To use it, you have to select one or more audio files in the right-hand column, right-click, then choose "Tools," and finally select the appropriate tool.)
Thanks @LyricsLover who started this discussion, and to all of you who participated. I believe your ideas and opinions have been invaluable in advancing our thinking about the new icons...
