Gday,
I find it annoying sometimes when I want to move (or copy) files and I get presented with the folder tree. The problem is when the folder I want is not close to the last one I used.
Currently the last used folder appears in the tree "on the bottom line". If the folder I need is not very close or if it is even just one line below then I have to go searching.
If it were in the middle of the directory tree that opens, at least I would have a little bit of latitude to easily select a different folder just by clicking.
What would be an even better solution would be if the last few (4 say) folders that I have used were presented as options (with a clickable button say) in addition to the directory tree.
Something along these lines would greatly enhance the pleasure of using this useful program.
All the best,
JakeStyles
