Edit tag if existing
Hi, there,
I'm trying to edit a tag that exists only in certain tracks with actions. However, if I do it with "Format value" it adds the same tag to files that do not contain it.
Now I would like to edit the tag without adding it to the files that don't have it.
Filter the files that have the special tag before.
i.e
%tagname% PRESENT
or add a filter to the format-value-action
if$(%tagname%,your content,)
How do I do that?
I'm new at this condition thing.
Can it be placed in an action?
Just take
$if(%tagname%,your content,)
as your format string in the action.
Edit:
Corrected type error: if$ to $if
You mean something like that?
Screenshot_3
obviously replacing by the corresponding label
Trying it that way removes the tag, i.e. it returns z
Edit: If it works, it's perfect. Just what I wanted.
MP3Tag is great.
Thanks you @poster <3
