Editing long string in Metadata Album in Adjust tag info dialog
See here.
When I edit a long field the horizontal scroll bar goes all the way over to the right and the edit box is no longer to be seen.
2023.07.19 (21-19-39)
Thanks for reporting! I'll look into this and hopefully fix with the next release.
It may have something to do with the UNS..LYRICS tag being so long in the GIF I posted.
Yes, ideally the edit field would use the visible width only and not the complete column width.
This is now fixed with Mp3tag v3.21c.
