Hello, I've been trying to edit the old albums, and some of the tracks have been replaced resulting in a mess with the track numbers. Is there anyway to fix them automatically? I've been really dying to know.
here's an example.
How should your tracknumbers look like?
1
2
3
or
13
14
15
or something else?
You could use the auto-numbering wizard CTRL + K if you like to use the GUI.
I'd love to see them as 13-15 vice versa. I have just fixed it with the auto-numbering wizard! Thank you so much for that. Are there any useful tools for a begginner like me? I really appreciate the help!
It depends on what you want to do.
You could start here:
