Hi I have some files named like this
Blown Away (Feat. Styles P) (Produced By Giorgio Tuinfort).mp3
I would like to delete the second parentheses and all the information it contains.
But at the same time some files are like this.
I Can't Wait (Produced By Akon).mp3
In which case I want to delete all.
I know that I can fix the second example with:
Regular expression
But the directory contains both types of names.
Ok I found this
/t/13480/1
In particular this post
'ft xx)' from Title to end of artist and remove '(prod. xxx)' from title
With that I get close but i want the (Feat.) to remain in the title and not be moved over to the artist.
dano
June 9, 2012, 7:58am
3
" ([^)]+).mp3$"
will only remove the last pair of parentheses.
Thank You. I set it as Replace with regular expression and it kept erasing the .mp3 from the file name and therefore rendered them as extension-less files but I got around it adding a step to add .mp3 to the title. Thank you
