Hello,
I would like to ask if embedded album art inside .mp3 or .flac files has a filename.. For example if the image was art.jpg will it have the same name inside the song? ![]()
Thanks for those who take the time to answer..
Hello,
No, doesn't have a name.
You can define a name for the export of the embedded coverart.
Thank you.
