English Help
Hi there, how do I get English help files for Mp3tag? In the help folder of the installation directory even though the help filenames are English the content is German. Thanks for any assistance.
You have to uninstall and reinstall Mp3tag (and choose English as language during installation).
Alternatively, you can go to https://help.mp3tag.de/ and browse it online.
Kind regards,
Florian
Florian
1: I wasn't given any option to select installation language but the program must just detect and use the system default. I am using a portable version which obviously doesn't detect the system default language.
2: I know I can view the English help files online but it's bit of a pain for accessing help from within the program.
Solution: I have installed the program, copied the English help files to my portable version and uninstalled.
Thanks for your prompt reply.
