First of all: is this the right place to ask for an enhancement?
I often need to check track lengths from sources like Musicbrainz.
When the track list is more than the display can show it would help a lot if you can browse down both sides at the same time keeping the tracks left/right on the same line.
Would that be possbile to add?
Right now the selected file in the right list can be moved up and down with the arrow keys next to the list.
A highlight in the left list shows which data the file in the right list would get.
So I think you simply would have to move the file in the list until it matches with an entry in the right list.
With any other behaviour I could not imagine how to make clear which file will get which data from the web source.
The way I understand it: you align a file with a list entry. And that means you have to move the file to certain position in the list.
Scrolling through the list prior to the alignment would mean that the list has to be inspected twice instead of only once.
Or the way I understand it: I take a file in the right list and move it up or down until I find a hit in the left list.
Wouldn't simultaneous scrolling detach the selected file from the current alignment and I would have to do it again?
Do you ask for some kind of synchronized scrolling?
So, if you move the list on the right down, the list on the left should scroll down too (and vice versa)?
The current status: You can move the lists on both sides individually
I indeed ask for some way of synchronised scrolling.
To accomplish this now I click twice on both sides to go 1 “page” down on both sides.
But when you want to align on some track half way the screen it gets more difficult (especially when 1 of the displays is shifted to the right so both displays show the track times).
Which you cannot scroll synchronously. Even when I enlarge the screen to full screen you are still missing tracks (this one has total of 63 tracks in MusicBrainz)
