Entire directory
I have a directory called "Music" and in that all my sub-diretories with my files. When I load Mp3tag it displays all my files if I choose c:\music has start folder.
Is there any way to get Mp3tag to only display my sub-directories?
You can disable the option Subdirectories at the File, Change directory dialog and browse your subdirectories via this dialog.
The directories are not displayed in the file view, because Mp3tag works only file based.
Best regards,
~ Florian
Thanks - even though I would have preferred to see the sub-directories... :wink:
