I am trying to export fields from 100 files to another 100, for the simple fields no problem, but when I try the comment and lyrics, I got the this warning:
Cannot parse line 1.
Cannot parse line 2.
Cannot parse line 3.
I discovered that the problem is that the original text in comments and lyrics has a paragraph with EOL (end of lines), a text like this:
"sadfhuif iuahduihaih doihiasdh oaisdh iouhf.
askdjfhf lkjsdfjl asdkj adj.
asduhiuhf.jdhdjjad."
So that not the whole text is written in the same line. The Export process ends with no problems, in fact, the file generated has all data. But when I import I got the message above.
Converting the fields for the same file in a unique line (removing all jumps and ends of line), I was able to import tags with no problems, but the comment and lyrics fields result in a oneline text (not aesthetic), as well It's not practical to remove all EOL from all comments and lyrics..
But that is what you have to do.
Create yourself two actions: the first replaces $chr(10)$chr(13) with a dummy character like # so that long strings become one line for export.
The other action reverses the replacing.
THe end-of-line character indicates the end of the record in the export ...
I do the replacement, and that's work. So in comment and lyrics I've e got a one line text. But which action should I use to invert the process, and get the text with "returns"=EOL.
I've used the replace action with $chr(10)$chr(13) and in the import option: $replace(%comment%,<<<,$char(13),>>>,$char(10)), where <<< and >>> are the dummy characters, but with no success. Hope you can help
Thanks
N.B: Literally, it does replace >>> or <<< with the $char(13) string and does not insert the return!!!
After importing the single-line-ified (previously multi-line) data into a tag-field, you have to do the reverse step on the content of the target tag-field.
DD.20120513.0755.CEST
Edit.
The replacement for CR-LF pairs can also be written as ...
