Same issue regardless of whether it is a master release or not.
I couldn't find any listing where I could copy/paste the info but in the end I asked AI and it gave me a listing I could copy/paste. I really don't like AI but clearly it has its uses!!!
I now realise my previous instruction was a little bit misleading. It works if you use, e.g., 2923068 or click on the release ID on the upper right which copies [r2923068] to the clipboard.
The first time I tried I copied the string with the brackets. That didn't work so I tried without the brackets. Are you saying it just wants the number without the r or m?
