Load the audible m4b to tag, run the search, finds lots of audiobooks this could be, find the correct one and select it and hit "Next"
It goes to searching / retrieving and then gives error "ERROR(L175/findline): text not found"?
Never had a problem for months, I am latest version 1.8.27
I originally first set this up months ago so cannot remember exactly how to use Web Sources?
I navigated to MacHD>Users>bart>Library>Containers>Mp3tag>Data>sources
(I had to create the "sources" folder) and copied over everything from the unzipped audible-api-0.3.0.zip
That works - BUT I had to remember to select the right source in the drop down!
Now I need to delete the old source files if I can remember where they are!
