ERROR(Settings): expected value, got ‘A‘ (65) when using Audible via API
I am running into an error trying to use this websource.
Settings of the Tag Source “A&udible API#Audible.com - Search by Filename” contain a syntax error:
See scripterror.log for details
Scripterror.log has only one line
ERROR(Settings): expected value, got 'A' (65)
I did notice that if i rename Audible API.inc to something else, i will get a prompt for a filename/album/asin but it wont find any results.
I have tried this on both version 3.32 and the beta 3.33 of mp3tag, both have the same problem.
I hope that this is solvable, i really like your software
It's missing the file A&udible API#Settings….settings (please note the special character …, which is, e.g., supported when unzipping the archive via 7-Zip).
Thank you, that fixed it!
