errors when getting tags from discogs
hello all,
it worked before but recently started giving the following error:
I use the discogs_release_ext4.src web source. tried re-installing the application with keeping the configuration files.
please advise, thanks in advance.
please see Discogs everything
I'm not sure where to continue the discussion - here or there
Discussion stays in /t/4346/1
discogs changed html layout a bit, the scripts must be adapted...
