Every album now shows the tracks, for example, 10 to 1 instead of 1 to 10.
I have tried the invert selection button but this does not work
This appear to have an effect when I try to play an album using my Blusound Vault.
If I select play an album in will play track 1 and then just repeats playing track one over and over
mp3tag - the list in the folder is fine, when I go into the album via mp3tag the listing is reversed
When I try and play an album it will play track 1 repeatedly
Did you know that MP3tag sorts by the contents of a column if you click on the column header? And it reverts the order when you click again.
So perhaps you click on the column that holds the track number until the sequence is right.
