Sorting Composer Fields with Labels and Separators
This document provides ready-to-use Mp3tag formatting actions for sorting fields that contain labels (for example Composed:, Music:, Lyrics:, Written:) and different separators such as commas, semicolons, and true multi-value \\ separators.
The formulas below have been tested with Convert > Tag - Tag and/or Format value actions.
Important
Always test on copies or backed-up files first. Some formulas intentionally convert between a true multi-value field and a single text value.
1. Sorting a Single Field with Label and Commas
Input
Composed: Kasa Allah, Benny Golson, Stuart Gorrell, Hoagy Carmichael
Output
Composed: Benny Golson, Hoagy Carmichael, Kasa Allah, Stuart Gorrell
Without label
For a true single-value text field whose items are separated by commas:
$sort(%composer%,', ')
With label Composed:
Composed: $sort($regexp(%composer%,^Composed:\s*,),', ')
Logic Flow
%composer%β reads the single text value.$regexp(...,^Composed:\s*,,)β removes the initialComposed:label and any following spaces.$sort(...,', ')β sorts the comma-separated names alphabetically.Composed:β is added back once at the beginning.
The older form
$sort($meta_sep(composer,),', ')can also work whenCOMPOSERcontains only one physical value, but%composer%is clearer here because this section concerns a single-value field.
2. Multi-Value Field Variant (\\ separator)
Example input
Composed: Kasa Allah\\Benny Golson\\Stuart Gorrell\\Hoagy Carmichael
Action
Composed: $sort($replace($meta_sep(composer,\\),Composed: ,),'\\')
Output
Composed: Benny Golson\\Hoagy Carmichael\\Kasa Allah\\Stuart Gorrell
Logic Flow
$meta_sep(composer,\\)β collects all values of the multi-valueCOMPOSERfield using\\as the working separator.$replace(...,Composed: ,)β removesComposed:.$sort(...,'\\')β sorts the values alphabetically using\\as the delimiter.Composed:β is re-added once at the beginning.
Assumption
This formula assumes that Composed: appears only as the initial label and is not part of a person's name or another value.
3. Case-Insensitive Label Variants
Mp3tag's fourth $regexp() parameter can enable case-insensitive matching:
$regexp(text,expression,replacement,1)
The final 1 means that the regular-expression match ignores capitalization.
Therefore the same expression can match:
Composed:
composed:
COMPOSED:
CoMpOsEd:
Single field β commas
Composed: $sort($regexp(%composer%,^composed:\s*,,1),', ')
Multi-value β \\
Composed: $replace($sort($regexp($meta_sep(composer,|),^composed:\s*,,1),'|'),|,\\)
Logic Flow for the multi-value version
β
Temporarily joins all values with |
$regexp(...,^composed:\s*,,1)
β
Removes the label regardless of capitalization
$sort(...,'|')
β
Sorts the values
$replace(...,|,\\)
β
Restores the true multi-value separator
Temporary separator rule
The character|is used only as a safe temporary delimiter. Use it only when|does not occur in the actual tag data.
4. Semicolon Separator Variants
Single field already separated by ;
If the field is a single text value whose names are separated by semicolons:
Composed: $sort($regexp(%composer%,^composed:\s*,,1),'; ')
Example:
Composed: Kasa Allah; Benny Golson; Stuart Gorrell; Hoagy Carmichael
becomes:
Composed: Benny Golson; Hoagy Carmichael; Kasa Allah; Stuart Gorrell
Convert multi-value \\ input to a single semicolon-separated value
Composed: $replace($sort($regexp($meta_sep(composer,|),^composed:\s*,,1),'|'),|,'; ')
This formula intentionally converts:
A\\B\\C
into:
A; B; C
So the result is no longer a true Mp3tag multi-value field. It is one text value containing semicolon-separated items.
5. Sorting Multi-Value COMPOSER with Two Fixed Labels (Music / Lyrics)
This version is positional.
It works only when:
- exactly two
COMPOSERvalues are expected; - value
0is alwaysMusic:; - value
1is alwaysLyrics:.
Input
Music: Tommaso Demuro, Steve Swallow, David Pritchard\\Lyrics: Gary Burton, Bill Goodwin, Apple Green
Output
Music: David Pritchard, Steve Swallow, Tommaso Demuro\\Lyrics: Apple Green, Bill Goodwin, Gary Burton
Action
Music: $sort($regexp($meta(composer,0),^music:\s*,,1),', ')\\Lyrics: $sort($regexp($meta(composer,1),^lyrics:\s*,,1),', ')
Logic Flow
$meta(composer,0)β reads the first physicalCOMPOSERvalue, assumed to be the Music block.$regexp(...,^music:\s*,,1)β removesMusic:case-insensitively.$sort(...,', ')β sorts the names inside the Music block.Music:β is added back before that sorted block.
Then:
$meta(composer,1)β reads the second physicalCOMPOSERvalue, assumed to be the Lyrics block.$regexp(...,^lyrics:\s*,,1)β removesLyrics:case-insensitively.$sort(...,', ')β sorts the names inside the Lyrics block.Lyrics:β is added back before that sorted block.\\β keeps the two values physically separate as a true multi-value field.,1β enables case-insensitive matching in each$regexp().
$meta(composer,0)and$meta(composer,1)select values by position, not by label content.
6. Sorting Music/Lyrics When Their Positions Are Not Fixed
This version solves two tasks at the same time:
- it normalizes the label order to the fixed canonical order Music β Lyrics;
- it sorts the names alphabetically inside each label;
- label recognition is case-insensitive;
- it works whether the input is
Music\\LyricsorLyrics\\Music.
Assumptions
- exactly two
COMPOSERvalues are expected; - one begins with
Music:; - the other begins with
Lyrics:; - the label starts at the first character of each value.
Action
$if($eql($left($meta(composer,0),6),Music:),Music: $sort($regexp($meta(composer,0),^music:\s*,,1),', ')\\Lyrics: $sort($regexp($meta(composer,1),^lyrics:\s*,,1),', '),Music: $sort($regexp($meta(composer,1),^music:\s*,,1),', ')\\Lyrics: $sort($regexp($meta(composer,0),^lyrics:\s*,,1),', '))
Logic Flow
reads the first six characters of value 0.
Then:
$eql(...,Music:)
asks whether the first value begins with Music:.
If YES:
meta 0 β Music
meta 1 β Lyrics
If NO:
meta 1 β Music
meta 0 β Lyrics
In both cases the field is reconstructed as:
Music: ...\\Lyrics: ...
Therefore the formula is normalizing, not simply positional.
Example A β original order
Example B β swapped input
Lyrics: Gary Burton, Bill Goodwin, Apple Green\\Music: Tommaso Demuro, Steve Swallow, David Pritchard
Both produce:
This is a fixed/canonical label order, not an alphabetical label order. Alphabetically,
Lyricscomes beforeMusic.
7. Automatic Sorting of Two Labeled Multi-Values: Labels + Names
This version performs two independent alphabetical sorts:
- alphabetical sorting of the names inside each label;
- alphabetical sorting of the complete labeled blocks themselves.
It is designed for exactly two labeled multi-values.
Action
$replace($sort($regexp($meta(composer,0),'^([^:]+):.*','$1'): $sort($regexp($meta(composer,0),'^[^:]+:\s*',,1),', ')|$regexp($meta(composer,1),'^([^:]+):.*','$1'): $sort($regexp($meta(composer,1),'^[^:]+:\s*',,1),', '),'|'),|,\\)
What this version does
- automatically extracts each label;
- does not require the literal words
MusicorLyricsin the formula; - removes each label before sorting the associated names;
- sorts the names alphabetically;
- rebuilds each complete
Label: namesblock; - sorts the two complete blocks alphabetically by their leading label text;
- restores the true multi-value
\\separator; - works regardless of which labeled block is initially value
0or value1; - label extraction itself does not depend on capitalization because no specific label word is hard-coded.
Logic Flow
The following part:
automatically extracts everything before the first colon.
For example:
Music
or:
Lyrics
This part:
removes the complete initial Label: portion, leaving only the names.
Then:
$sort(...,', ')
sorts the comma-separated names inside that block.
The same operations are performed independently on $meta(composer,1).
At this stage the two reconstructed blocks are temporarily joined with |, for example:
Music: David Pritchard, Steve Swallow, Tommaso Demuro|Lyrics: Apple Green, Bill Goodwin, Gary Burton
Then:
$sort(...,'|')
sorts the complete blocks alphabetically according to the text at the beginning of each block:
Lyrics: ...
Music: ...
Finally:
$replace(...,|,\\)
converts the temporary delimiter back into the true Mp3tag multi-value separator.
Why the regex patterns are quoted
These two patterns contain square brackets:
'^[^:]+:\s*'
In Mp3tag Format Strings, [ and ] have their own special meaning. Wrapping these regular-expression patterns in single quotes prevents Mp3tag from interpreting the square brackets before the pattern reaches the regex engine.
Example 1
Input:
Output:
Lyrics: Apple Green, Bill Goodwin, Gary Burton\\Music: David Pritchard, Steve Swallow, Tommaso Demuro
Example 2 β swapped input
Input:
Output:
Assumptions and limitations
- Exactly two physical
COMPOSERvalues are processed because the formula explicitly references$meta(composer,0)and$meta(composer,1). - Each physical value must begin with a label followed by a colon, for example
Music:orLyrics:. - The label itself must not contain an additional colon before the separator colon.
- Names inside each block are expected to be separated by
,. - The temporary
|character must not occur in the original tag data. - Sorting behavior is provided by Mp3tag's
$sort()function; this formula does not add a separate case-sensitivity option to$sort().
8. Function Reference Used in These Examples
$sort(x,y)
Sorts the segments in x using y as the delimiter.
Examples:
$sort(...,'\\')
$sort(...,'|')
$meta(field,n)
Returns the n-th physical value of a multi-value field. Indexing starts at 0.
$meta(composer,0)
$meta(composer,1)
$meta_sep(field,separator)
Collects all physical values of a multi-value field and joins them temporarily with the chosen separator.
Runs a regular-expression replacement. The optional fourth parameter 1 enables case-insensitive matching.
$replace(text,search,replace)
Performs a literal replacement and is useful when regular expressions are unnecessary.
$eql(x,y)
Compares two strings. In the formulas above it is used to detect whether value 0 begins with Music:.
9. Choosing the Correct Formula
Use the formula that matches the real structure of the field, not only what it looks like in Mp3tag.
| Scenario | Recommended section |
| One text value, names separated by commas | 1 |
True multi-value field separated by \\ |
2 |
| Label capitalization may vary | 3 |
| Single text value separated by semicolons | 4 |
| Convert true multi-values to one semicolon-separated string | 4 |
Exactly two values, fixed Music then Lyrics positions |
5 |
Exactly two values, Music / Lyrics positions may be swapped, but output must always be Music β Lyrics |
6 |
| Exactly two generic labeled values; both labels and names must be sorted alphabetically | 7 |
Notes
- All examples are intended for Convert > Tag - Tag or Format value actions.
- When adapting the examples to another field, replace the field consistently everywhere. For example, changing
COMPOSERto another field may require changing%composer%,$meta(composer,...), and$meta_sep(composer,...). - A displayed
\\separator represents separate physical values in a true multi-value field; a comma or semicolon inside one value is only text unless the field is explicitly split into multiple values. - Temporary separators such as
|must not occur in the source data. - Re-running the normalizing formulas on already normalized data should leave the logical result unchanged, provided the stated assumptions are respected.
- Always back up your files before using bulk actions.
- If you find errors or want to improve the formulas, feel free to edit this document.
- Thanks, ChatGPT, for the help.
