I cannot reproduce what you said. I just tested MP3Tag with 1152 audio files (mostly MP3 - some WavPack) and the memory usage was below 15 MB. Adding a comment and then removing it resulted in a memory usage of 25 MB.
Edit: I have a Windows XP Home, running on an Intel Pentium 4 HT with 3.2 GHz, 1 GB RAM.
ASUS A7n8X motherboard with latest Nvidia Nforce 2 Drivers
WinXP Pro SP2 - With all security fixes
Audigy 2 Soundcard - Latest Drivers
ATI Radeon 9500Pro - Latest Drivers
Very little else is installed at the moment, just some CD/DVD Writing software as I am archiving off data.
I was surprised with this behaviour as I have used MP3Tag for a while, the last version that i was using was about 18 months old as it was working fine and there was no reason to upgrade until now when i reinstalled windows.
The way that i got the listing of the files was to right click on the top level music folder in windows explorer and then select Mp3Tag from the context menu. I have my music arranged in subfolders for each album.
e.g.
Music
|- Album 1
|- Album 2
|- Album 3 - Disc 1
|- Album 3 - Disc 2
etc.
It appears that a lot of the files have got embedded artwork that I haddn't spotted before. I usually keep the artwork in the folder, but this is in the tags.
Thus there are a lot of files that have tags that are > 0.5 Mb in size!
This would account for the memory usage.
What is the best way for dealing with this embedded artwork? I would probably want to save a copy into the folder as an image and then strip it from the tags to save duplicating the same image 13+ times!
Judging by the memory usage this would save me around 300 Mb from by collection!
Is there a good reason to store the artwork in this inefficient way?
Thanks,
Graeme
p.s. please feel free to move this to the support forum, as this is clearly user error and not a bug in Mp3Tag
