Hi all,
I am a huge music enthusiats along with computers and use both, I was looking for a tagger program with some features like FLAC support, album art and of course batch tagging and I stumbled upon this program within 20 minutes I was pleased. I also wanted something that integrated with the Windows shell (right-click editting) and literally jumped for joy when I was playing around with Mp3tag
I would like to add my suggestions for the next version or beta, so please everyone feel free to comment.
Dear Author/creators:
Suggestions for Mp3tag v2.39 or 2.38b
Suggestion # 1 - shell popup menu - I feel this small feature should be in Mp3tag, I have seen it in two programs already and they are dbpoweramp 12 and also lightweight and pleasant the freeware audioshell, we should have the option if we want to install this shell - see preview pic of dbpoweamp's that I took (notice how dbpoweramp gives lovely advanced information such as record label and vbr settings _ v extreme)we could also have the option of what tags to see in the popup too
Suggestion # 2 -Input a URL to for an image - Now that we can paste album art, I would now love the abilty to input any direct image link (for example, www.mysite.com/albumartpic1.jpg) so that the program can quickly download the image, this great feature would suite nicely, this feature should too be able to: resize the image to gievn dimensions before writing as art to the file, also have a login and password filed in where if the site requires to login then user can input login and pass
see the screenshot I have taken of this program and editted to show you all what I mean
as you can see from the image that I enjoyed editting in MS Paint it would be nice, NOTE: the 'configure' button would do - login and password field, set image dimensions, rename image, internet-proxy settings. All images downloaded can download into a TEMP directory first or can download straight into the program whichever is best.
that image took me 1 hour to create edit so good luck and thank you for viewing
More advanced tags and the option to show them as default - Record Label, URL, composer, disc number, ripping tool, enocoder, language, rip date, copyright - I really am interested in the 'record label' tag that can sometimes go under the tag name of 'Publisher' or simply 'Label' if they are in the program I just can';t seem to find them http://i11.tinypic.com/5yd0diq.png
see this image (same image) -
SORTED - This program just keeps getting better and better, I found it its ok - File>Options>tag panel - I could add my own default entries, including 'record label' (which is under PUBLISHER) entries FANTATSIC this is what I have always wanted to do - tank you Florian
Every feature from within this beautiful program should be kept the way it is and nothing should be taken away, I will shut up now.
- option giving simple
) and used such extensions myself. When I can do it manually without a reboot, I don't see any reason why an installer cannot do it, too.
While this program doesn't allow you to de-install them (regsvr32.exe /u) it gives you the path to the file, with which you can test such an de-installation. Also try to just disable an item and then deleting the file (but make a backup), it should work, too, which means the file can be replaced or removed, EDIT: here the same thing applies as with the manual unregistering... you have to close all explorer windows afterwards for it to work, or rather all processes that might have the file locked... I'm not sure whether this is the case always, or only for some shell extensions, I have seen both cases therefor I guess it's either up to the developer to write a "clean" implementation that issues the explorer to let it off the hook or it depends on the functionality of the extension.
