Is it possible to export the bpm fied ? If yes how would the config look like in the csv template ?
Thanks
Thanks
You would only have to add the variable %bpm% in the line
$loop(%_filename_ext%)%title%;%artist%;%album%;%track%;%year%;%_length_seconds%;%_file_size%;%_file_mod_date%;%_folderpath%;%_filename_ext%;
and but a semikolon behind it.
Ok thanks. I thought i did that but it didn't work the first time. I've noticed though that re-editing the same template over and over doesn't seem to work very well (to shift the position of a tag for instance). What works well is to duplicate a template and edit it to create a new one.
Anyway, this is such handy piece of software. Muchas gracias
