export by genre
Hi, long-time user (many years), first time poster.
I recently started using MP3TAG for exporting also; I have used it for years for tagging. I took some exports I found in these forums, and customized them for my own uses. Many thanks to you experts who posted your export creations! :smiley:
What I can't figure out is how to create a loop that only shows a certain match. I can do loops, and even figured out how to sort the loop. But what if I only want to export if the genre is "XXX"?
Right now, to do this, I have been exporting sorted on genre, then editing the HTML file and deleting all but the genre I want. But surely there is a way to limit the loop to only a specific criteria.
Thanks in advance; I LOVE this program.
Stuart
Houston TX USA
PS: Here is a link to the pages I have created with exports:
http://texasfeldmans.com/pages/stuart/music.htm
You mean something like this:
$if($eql(%genre%,XXX),%genre%,)
If genre equals XXX then return genre else do nothing.
Thanks. Do I put that directly before the LOOP statement? Does it need any closing line, or just that?
I would try it now, but I am at work, and my Mp3Tag is at home . . . :sunglasses:
It doesn't need any closing line.
You can:
  • replace directly with "%genre%" anywhere in code
  • put it inside the loop
    example (simple table):
    $loop(%genre%)$if($eql(%genre%,XXX), ,)$loopend()
    %artist% %genre%
Got it working, THANKS!
Question Part II :music:
How do I make the IF have a multiple choice. In other words, if the GENRE is XX or YY, then...
Thanks! :book:
Mp3tag have great help.
Why don't you read & play with scripting functions it's fun. :slight_smile:
$if($or($eql(%genre%,XX),$eql(%genre%,YY)),%genre%,)
If genre is XX or YY then return genre else do nothing.
Thanks for the help. I actually started reading the scripting functions last night, and found a whole new world of fun! :ph34r:
Many thanks!!
