Export configuration
Hi Florian,
Long time ago ...
Having problems with ID3V2 tags, i've just upgraded from release 2.28 to 2.36a.
It's working great (and easier comparated with my old version 2.28) but i've a little problem with my export configuration created in 2.28 :
[EXPORTHEADER]
HEADERLINE01=Configuration JM n´Zou pour EXCEL
HEADERLINE02=A ouvrir via "EXCEL - Fichier - Ouvrir - Tous les fichiers (*.*) - Délimiteur point-virgule" et pas via un double click en EXPLORATEUR
HEADERLINE03=
HEADERLINE04=INTERPRÈTE;TITRE;ANNÉE;GENRE;ALBUM;COMMENTAIRE;DURÉE;TAILLE en Kbytes;RÉPERTOIRE;NOM DE FICHIER;ENCODEUR;
HEADERLINE05=
[EXPORTRECORD]
RECORDLINE01=%artist%;%title%;%year%;%genre%;%album%;%comment%;%_length%;%_file_size_kb%;%_folderpath%;%_filename_ext%;%encodedby%;
[EXPORTFOOTER]
FOOTERLINE01=
[EXPORTSORT]
SORT=3 1
[EXPORTEXTENSION]
EXTENSION=csv
, because after having selected all my songs, the software writes me this :
HEADERLINE03=
HEADERLINE05=
RECORDLINE01=ELMER FOOD BEAT;A L'interieur;1989;;30 Cm;©1989;02:48;3277,38;D:\Zou\Mes documents\Easy CD Extractor\OK - FORMATE\Elmer Food Beat - 30 Cm\;ELMER FOOD BEAT - A L'interieur.mp3;;
FOOTERLINE01=
SORT=3 1
EXTENSION=csv
Your help would be (as usual :slight_smile: ) very appreciated ...
Thanks in advance !
Why didn't you post this in Export subforum?
You must use loop if you wont tag informations from all files.
The problem is that you have the old export format, but this is not supported anymore.
You must change it to this:
$filename(csv)Configuration JM n´Zou pour EXCEL
$loop(%_path%)%artist%;%title%;%year%;%genre%;%album%;%comment%;%_length%;%_file_size_kb%;%_folderpath%;%_filename_ext%;%encodedby%;
$loopend()
Sorry, I did'nt see there was a special sub-forum for this specific point :slight_smile: :slight_smile: :slight_smile:
QUOTE (dano @ Aug 7 2006, 12:10) <{POST_SNAPBACK}>
$loopend()<!--QuoteEnd--></div><!--QuoteEEnd-->
Thanks for this helpful (and prompt ...) reply, Dano ...
