Export is screwed
:frowning:
A bunch of placeholder doesn't work anymore:
artist
album
comment
genre
title
track
year
_tag %_tag%
_tag_read %_tag_read%
_tag_size_appended %_tag_size_appended%
_tag_size_prepended %_tag_size_prepended%
As you can see, the first ones return nothing, the others just their name
Yes, you're right. I'll remove the Development Build now, cause I have no solution for this problem at the moment.
Please use V.2.20 stable for the moment.
Best regards,
~ Florian
I've hopefully fixed that problem and I think that all placeholder related functions are working correctly with the latest Development Build now.
Best regards,
~ Florian
