hi there, i made a simple export template:
$filename(Trackliste.txt,utf-8)
%album%
$loop(%track%)$num(%track%,2) %title%
$loopend()%_length_seconds%
now i want to print "95 minutes" instead of "1:35:00" or "5700 seconds".
how can i do some simple calculation? i only found about string functions...
thx in advance
thank you it works well.
but somehow i now messed up:
i want the length of all Tracks but the export only gives me the length of the 1st Track.
all files are processed but %length% now has only the time of the first track...
i also tried to workaround by using $puts $get and $add but don't really understand the typo...
Export Mp3tag Global Placeholders
$filename($getEnv('TEMP')'\Test.txt',ANSI)'Mp3tag version: '%_app%
'Following values are provided without a previous "loop/loopend" structure.'
'Total number of files (%''_total_files''%): '%_total_files%
'Total file size (formatted output) (%''_total_size''%): '%_total_size%
'Total file size in bytes (%''_total_size_raw''%): '%_total_size_raw%
'Total playing time (formatted output) (%''_total_time''%): '%_total_time%
'Total playing time (formatted output without days) (%''_total_time2''%): '%_total_time2%
'Total playing time in seconds (%''_total_time_raw''%): '%_total_time_raw%
DD.20160325.1326.CET
Example export script, returns for one album a tracklist ordered by CD ...
1: $filename($getEnv('USERPROFILE')'\Desktop\'$validate(%ARTIST%'.'%ALBUM%'.Tracklist.txt',),UTF-16)
2: %ARTIST%' - '%ALBUM%' - '%YEAR%
3:
4: $loop(%DISCNUMBER%)'CD '%DISCNUMBER%
5: $puts(my_Counter,0)$loop(%_filename%)$num($put(my_Counter,$add($get(my_Counter),1)),2)'.'$char(9)%TITLE%$char(9)%_length%
6: $loopend()'---'$char(9)'Gesamtdauer'$char(9)%_total_time2%
7:
8: $loopend()
DD.20160325.1351.CET
