Whenever I export now to CSV, the values that get exported are the following
Title/Artist/Album/Track/Year/Length/Size/Path/Filename
I want to add other things to the export such as genre, comments etc...
How can I make this possible?
Thanks
Thanks
You have to edit the export-file:
The list from which you envoke your export has buttons on the right site.
One of them is edit.
For further instruction about exports look at the help of Mp3Tag.
Whenever I press on that, I get the attached error.
I think edit is opening with my uTorrent application.
How to bypass that?
Set a decent editor as default program for pain text editing?
Or navigate to the export script folder (somewhere here: /t/964/1
Works fine now.
Thank you so much for your prompt replies.
