Export mp3 to browser not working?
trying to export mp3 list to html standard& html mp3 tag then it open s up with u Torrent not chrome or any other file exporer ie edge what is going Wrong even if i uninstall this still wont work??
If you double click on the exported .html file it will not be loaded in your browser?
If yes: You can assign your standard software for every extension like .html
Just right-click on your .html file in your Windows File Explorer and choose "Open with..."
Then select your browser like Microsoft Edge or Google Chrome.
Or you follow this instructions, depending on your Windows OS Version:
