hello my question is how to export multi filenames to .txt format
thanks
thanks
nobody????? ![]()
Please rephrase what you want to do.
What application do you want to use to fulfill the task?
DD.20101213.1734.CET
simple filelist:
$filename(txt,utf-8)
$loop(%_folderpath%)%_filename_ext%
$loopend()
filelist with path:
$loop(%_folderpath%)%_path%
$loopend()
more help & placeholders for mp3tag export:
https://docs.mp3tag.de/export
filelist for all kind of files:
http://www.karenware.com/powertools/ptdirprn.asp
$loopend()
filelist with path:
$loopend()
