when I try to export a filelist with longer pathnames, it shortens it like the dosbox does. It then looks like this:
C:\temp\mp3\sarasa\zugeordnet\ELECTR~1\01
You see the "~"?
I am using MP3Tag Pro, still in trial...
I didn't find anything about it searching the forum. Is this a known issue? Is there a workaround?
I need the full path cause I want to re-import it afterwards.
Thanks for you help!
Riesi
