Export Question - VBR Folders...
#1
Is there a way to Export the Average Bitrate of a folder that is VBR?
Will durchschnittliche Bitrate pro Album exportieren
avarage bitrate - export
#2
This is from my config:
$loop(%_filename_ext%)$puts(Vbitrate,$add($get(Vbitrate),%_bitrate%))$puts(cnt1,$add($get(cnt1),1))$loopend()$div($get(Vbitrate),$get(cnt1))
As told here.
Try to use the search function, please.
#3
Thanks for the info.
#4
Is there anyway to do this for just a text file?
#5
What do you mean?
You can put that code in any config.
#6
I didn't know if I could only use that for HTML exports, but I got it figured out, thanks!
